I have a Sencor TC-109 tube checker.
I'd like some help calibrating it. There appears to be a means to adjust this under the top plate. There's a tube there "under the hood" and a screw so I'd assume you get a VOM and make an adjustment to the Sencor to have it accurate.
I realize that on top there's a "CAL" setting and you turn a screw there to zero out the needle. I know how to do that.
Thank you guys,
Mark
Thank you guys,
Mark
