Calculations are mud
Feel free to explain.
I like to point out the limits of mathematics. Did you know there is no closed form for the length of a sine wave? This is one of the most fundamental objects in nature. The basis for huge stores of human knowledge, and we can't even calculate its length, only approximate.
This is when the theory exists. Did you know there is no accepted theory of turbulence? A scientific idea which heavily influences speaker design. There's nothing to solve, because we can even decide how it works.
It's my opinion that better results can be achieved through common sense, than with simulations.
Can you think of a reason you might want to know the length of a sine wave, and does it matter that there is no closed form solution? I can think of a reason we should know the circumference of an ellipse and there is no closed form solution for that either, but we can get as close as we want numerically for either one.
Common sense isn't. The only limit for mathematics is the imagination you don't seem to have.
I think it's a fundamental misconception believing that mathematical models do or claim to entirelly tepresent reality.
Mathematical models are used to model aspects of reality in a required or sensible accuracy. Some model still need to be invented or developed.
By the way: what's the connection with multi-way?
Thank you for that, such a relief i wasn't aware.
Opinion is nice, everyone as one. Same with... but i disgress.
So common sense should be the mother of all invention, that's it? Hmm... how do you define common sense?
It have always been a struggle to define it in human sciences ( psychology, sociology,...).
Last time i've seen something starting like that in real life it ended defending earth is flat as the guy never experienced earth curvature by himself and it was all a conspiration...
I will keep on using a computer to simulate things, thank you.
By the way do you think it's common sense and trial and errors which made you able to type your opinion over the web? ...or application of mathematic's theory?
