Complete dac board from CAL CL-15 HDCD player
PCM1702 with Power Boss power supply(BIG)
Fully discrete output (i/v)
'Super cap" on dac power pins
PMD100 HDCD decoder
CS8412
Twin transformers
This board has a bad main processing ic , so the unit would no longer turn on.
I sold the disc drive ; only the board and chassis are left
Very well engineered circuit board. Bypassing the main ic or rerouting the power to the dac section will be required.
$75+ shipping. Chassis available for just additional shipping. .
PMD100 HDCD decoder
CS8412
Twin transformers
Just a note ; this board has a digital INPUT in it's design. The player was able to be used as a DAC and a cd player.
Homemade,
Is this still for sale?
If it is do you have the schematic for it and would you consider posting it to Australia at my cost and risk of course?
thanks
ekidnah
thanks
ekidnah
Do you have schematic to connect CS8412 to PMD100?
I would like to connect SPDIF to CS8412 and then to PMD100 of my Old CD player Rotel RCD-971.
I only found CS8412 to DF1700.
I think DF1700 and PMD100 has adapter but I only found adapter of PMD100 to DF1700
Hence my CD player has PMD100 so I want to connect CS8412 to PMD100 directly.
Thank you very much
Thank you very much
Thank you very much
