cable sleeve size
hello,
i wanna ask you about the expandable cable sleeves because i have never used sleeve on cables. I want to dress a 7mm diameter audio coax cable with sleeve. Whitch size will i need? Can i use a 6mm sleeve (smaller will be better-tighter because it is expandable) or 7mm diameter?
thank you
george
