I don't know where to post this because I am a total noob.
I was given a Sanyo DWM-3500, an older 5.1 surround sound system with a powered sub and a main unit. I would like to connect my existing receiver to it so that I can simply use it as a powered sub. The problem is that I am missing the main unit which the sub connects to via a DIN-9pin.Im not sure if its proprietary or if it follows a template/standard. Like I said I want to simply use it as a powered sub that I can hook to the subwoofer out jack on my current receiver (sony str-dh750).
AUDIO INPUT (6-CHANNEL):
DIN 9-pin
SPEAKERS (Output):
FRONT (L/R): 8 Ω
CENTER: 8 Ω
SURROUND (L/R): 8 Ω
Power requirements:
AC 120V, 60 Hz
Power consumption:
150 Watts
Unit used:
6.5" (16 cm) diameter, Cone type
Satellite Speaker
Front left, Front right, Center, Surround left, and Surround right speakers
(SX-TS3000S, magnetic shield)
Unit used:
3.1" (8 cm) diameter, Cone type, Full range
Maximum music power handling capacity:
50 Watts
Nominal impedance:
8 Ω
How do I go about simply using this as a powered sub? And is it even possible? (although it seems like it should be because the amp and sub just need
DIN 9-pin
SPEAKERS (Output):
FRONT (L/R): 8 Ω
CENTER: 8 Ω
SURROUND (L/R): 8 Ω
Power requirements:
AC 120V, 60 Hz
Power consumption:
150 Watts
Unit used:
Satellite Speaker
Unit used:
50 Watts
Nominal impedance:
8 Ω
Open the box and put up the photos here. Earlier query regarding this on this forum had no outcome.
http://www.diyaudio.com/forums/pc-based/188356-convert-din-9pin-6channel-3xtrs-3-5mm-noob-help.html
Gajanan Phadte
Gajanan Phadte
