Bypassing cathode resistor on pp power tube
I currently travel across canada and i have a small repair to do for
a friend the amp is a custom special 100 traynor
the four cathode resistor of the power tube blown
it should be easy to replace them but Im staying in this town
for a limited time and theres no electronic part supply in the region
im relatively new to guitar amp repair but i know theres a lot of desing
that just dont use cathode resistor
can i just bypass them?
thanks
Traynor has the user manuals with schematics online.
Looks like they are 1R resistors. If all four blew, something else is wrong. You can jumper over the resistors, but something else is going to blow, like the tubes. Failed bias would explain it.
