Building a bluetooth speaker from scratch
Hello everyone.
I'm new to the audio world and I'm willing to build a bluetooth speaker from scratch.
I do understand a little bit of eletronics so I think I'll be able to put everything together, but I'm not sure if the components I choose will give me a good result, I've being studying about DIY speakers for about 20 days and I would appreciate a feedback about what I could change to get the best results.
Here the components:
2x AIYIMA 3inches 4ohm 40W full-range speaker
2x GHXAMP 1.25inch (30mm) 8ohm 10W neodymium
2x Harman/Kardon passive radiators 4 inches (121mm)
1x WAVGAT TPA3116 50w + 50w amplifier
2x PAPRI Axial Capacitor 3.3uf 400vdc
5x Thermostat 250V 5A 60ºC
8x BASEN 18650 battery 3.7v 30a
1x WAVGAT 4S 30a 14.8 protection circuit board
1x KingWei Charger 16.8v 2.0a
1x 24v switch
Schematics:
I also created a wishlist on aliexpress just to be easier to check the components I picked, here is the URL for the wishlist: AliExpress.com : My AliExpress
Also, if I use a 2-way crossover instead of the axial capacitor it will give me best results or it will be similar?
Thank you for your help.
