I'm seriously considering a 2x4 rev.B and want some claification on two points.
1. With the 2way advanced plugin can I introduce 3-6 db of baffle step compensation (shelving network)?
2. It appears to be the case but can I add a LR4 pass filter at 100hz while simultaniously having an LR 8 low pass at 2k on the same output?
Thanks.
Thanks.
You could indeed do all that with the Advanced plug-in and using custom biquad programming. Just cascade your filters in the biquad sequence.
As for the shelving, it's already all there with control of the Q. Have a look at the manual/video for more info
DevTeam
DevTeam
