Alex-
Did you ever find a Bruel & Kjaer 2203 service manual? I'm looking for one too. My 2203 measures about 20 db low, I suspect the polarization voltage is the problem. Did you fix your meter?
Thanks,
Mark
Thanks,
Mark
The schematic on Radiomuseum.org is for the tube version only. Does anyone have the FET version?
I noticed there's a quick disconnect connector on one of the wires that may be associated with the 200v polarization voltage. Does anyone know the purpose of this? Is there a reason to disconnect the polarization voltage for some microphones that can be used with the 2203? Or is this some kind of test mode?
Not all mics require the voltage. I found both versions when I looked!
HI chaps,
I wonder if any of you ever got hold of service information for that B+K 2203 Sound level meter?
I have contacted B+K this week and they no longer support this model , neither do they have any remaining service data for it...:-(
The serial number of my instrument is 887512 making it a later NON thermionic tube/valve input device.
Looking inside the pcb's are littered with silicon transistors and a couple of what look like op-amps.
Can anyone supply me with the correct service data for this model please?
Thanks in anticipation
Dave
Dave
I now have a free copy of the B+K 2203 service manual in .pdf format if anyone is still looking for it!
Dave
Dave
Hi Dave,
I almost forgot about this, and I'd love to have a copy. You have a Private Mail from me!
Alex
Alex
Hi Dave,
If you look at the top right of the diyaudio page, just under "welcome, davebullock" there is a link called Private Messages, and you should have 1 unread from me.
Alex
Alex
love to have a copy
Hi Dave, I would be very pleased to have one
Adrian
Dave
Adrian
2203 service manual
Hi Dave,
I'm interested too in a 2203 service manual... I'll be very happy if you can send me a copy. (I have one not working 2203)
Thanks in advance
Juan
Hi Dave,
Thanks in advance
Juan
Also love to get a copy
Hi Dave,
I would greatly appreciate a copy of the 2203 service manual. My meter just died and I've been searching everywhere for a service manual.
2203's above sn598006 are quite different from earlier models, 1/2" mic socket, fet input and ICs replace discrete components.
All the components in mine seem fine except for one IC I can't identify, an AD3226.
Murray
Hi Dave,
Murray
Request for B&K 2203 manual
Dave,
I have sent you a private email with my real email address. I also would like a copy of the manual.
Thanks,
Cliff
Dave,
Thanks,
Cliff
ZC0009 preamp
Does anyone know if the ZC0009 microphone preamp is interchangable with other preamps, like 2619/2639? So, can I use this with other instruments, like 2607 etc?
Sorry, I mean ZC0007!
Anyone still have a service manual available?
Hey! I'm hoping to revive this thread. I need a 2203 service manual. Looks like I have the FET version as well. Does anyone still have a copy available that they can send me?
Thanks!
Thanks!
Hi!
I need a 2203 FET version service manual too. Help me, please ;..-|
Thanks in advance,
Alexander.
Thanks in advance,
Alexander.
Hi dave bullock,
If possible i am interrested by a copy of the service manual of 2203 B et K.
I'l give you my PM if necessary.
Regards,
Michel
Regards,
Michel
- Design & Build
- Equipment & Tools
- Bruel & Kjaer 2203 service manual
