Broken Samsung 150mp HELP w/VGA
I got my monitor totally mounted in the box, and went to hook up the vga cable to a computer. Originally I used a different VGA cable and it worked fine. This time I hooked up the VGA backwards, and got a repetitive beeping and a slight burning smell from the board connected to the monitor. I didn't even know that you could hook it up backwards!!
I can see that position D104 on the circuit board is toasted. This is a very small rectangle with 3 contacts (ignore the dots, they are there to make it show up right):
It looks like this is one of 8 rectangle things that connect to the 15 pin Dsub VGA plug.
Does anyone know what this is, or where to find a replacement? Does anyone have a 150mp circuit board lying around that they would be willing to sell for cheap? It is the board with the 12volt, VGA, RCA Video, and s-video.
I will try to get a picture of it shortly.
All of the other video/TV functions still work properly, it just will not take a VGA signal! HELP!!!!
