Hi @all,
i work the last days on a broken amp. One fet in channel 4 was broken.
3 channels run fine. If i replace the broken, the new one gets in a few seconds really hot and the amp goes in protect.
I see that between gate and source was a difference of 6V DC. None of the other channel has it.
I replaced all the green marked fets, transistors, diodes, OP amp too.
but it will not work.
Anyone any idea?
Dropbox - IMG_20200630_211903.jpg - Simplify your life
Anyone any idea?
Then it runs in protect. without fets.
All other gates have +-28V. The broken one has 24V.
If i set the pot the voltage of the NPN fet decreases too
when i set the pot the NPN decreases, too.
And i think the amp goes to protect. but i will try this tomorrow.
+VCC side runs, every voltage is correct.
Hello, change the Mosfet with a new one. Turn the Bias Pot fully conterclockwise. From my expirience, the SMD transitors in front of the Fet are leaking, so change them, even if they measure ok.
Then it should work. After that, increase the bias, until the current starts raising a little bit.
- General Interest
- Car Audio
- Broken Amplifier Audio System F4-380
