Is it possible to bridge two GC circuits - I'm thinking of bridging two LM3875 devices - is it possible, and how can it be done ?
Should it be driven by a balanced source ?
What would the power be - 150watts ?
Cheers !
Hans
Cheers !
Hans
App notes
Take a look at the National Overture app notes - it describes bridging and paralleling up to 200w.
Re: App notes
do you have a link?
Sawzall said:Take a look at the National Overture app notes - it describes bridging and paralleling up to 200w.
do you have a link?
I believe they were referring to this application note:
http://www.national.com/appinfo/audio/files/BPA-200_Application_Note.pdf
or
Look at part 7.0 (pretty much the same as above) at this link:
http://www.national.com/an/AN/AN-1192.pdf
Hope these help.
or
Hope these help.
Just a note... i get 220W out of my bridged LM3886s.
Just bridged (2 devices), not bridged+parallel (4 devices).
I run them at +-40V and they are VERY will heatsinked.
Mats J said:I believe they were referring to this application note:
or
Hope these help.
thanks, just what i wanted 🙂
Which schematic are you supose to use? Or will any do?
Edit
Figure 17 looks ok. But i dont know which tree pins to use.
I guess that it will run fine with lm3875 too
Edit
Here's a thread right here on DIY Audio
How can people like Peter Daniel not be tempted to try a bridged
amp? They are in a position to see if there are sonic compromises.
http://www.diyaudio.com/forums/showthread.php?s=&postid=181872#post181872
- Chip Amps
- Bridging of the Gainclone ??
