Check the XLR pinout. GND is not usually in the center (odd but true).
And.... a lot of XLRs in hi-fi and even in full pro audio are not push-pull. A lot are single-ended with "ground balance" or "ground sensing" or just plain unbalanced. Here that is a waste of a LM3886 and its heat.
I honestly did not know the actual pin-out of the XLR (the image is just an example to illustrate the question)Check the XLR pinout. GND is not usually in the center (odd but true).
are you saying using a bridged lm3886 is not recommended?Check the XLR pinout. GND is not usually in the center (odd but true).
No he's saying you shouldn't assume that the XLR carries two 180-degree out of phase signals on pins2 & 3.
but if it is input is truly balanced, the circuit would work?No he's saying you shouldn't assume that the XLR carries two 180-degree out of phase signals on pins2 & 3.
Yes, I can't see why not. But note that the circuit isn't complete, no power supply or muting components are shown.
- Chip Amps
- bridged/balanced LM3886 - would this work?
