Here is a picture of a Brax car amplifier posted
by a member of the CAF forum.
I see four rectifiers in a To247, part number FEP30DP,
common cathode.
http://markg.fortunecity.net/images/brax5.jpg
other side of amp.
http://markg.fortunecity.net/images/brax4.jpg
Four sets of diodes in common cathode, have you
seem this configuration to form a standard bridge
rectifier *or* is this a more exotic DC-DC converter
design ?
common cathode.
other side of amp.
design ?
I've known diy psu's where builders used a similar setup and wired both diodes in each case parallel to form 1 rectifier bridge.
