Happy to, but don't know what's needed as I was specific about where the issues were and what needed to be changed to make the site more mobile friendly. Any questions in particular?
No that's fine. If there is nothing else, I'll just repost your specific comments about breakpoints here so we can be sure they are addressed:
So the above will be reviewed in due course. When you say default behavior do you mean the default for XF 2's stock style, or do you mean the default in terms of generally accepted UI best practice for the web as of today?
Your current breakpoints are 650, 900, and 1200. You're dropping the right columns at 900, whereas default behavior is to reduce their font size at 900, and drop them at 650. Additionally on /community you're dropping the right columns at 1200 where it should be 900 by default with sidebar on, and 650 with sidebar off.
I was iPhone 11 Pro Max when I reported the issue, and am now 13 Pro. AFAIK, of the most popular phones, only the iPhone 12 and 13 Pro Max have a landscape viewport width larger than 900, at 926.
I believe it's default XF2, unless the three XF2 sites I visit all just happened to set theirs up the exact same way, which is possible.
Another report of this issue here: https://www.diyaudio.com/community/threads/information-displayed-on-thread-list.381398/ (that thread now locked - discuss here).
But it does happen in landscape mode. The tablet's resolution is 2560x1600, which should be enough.
Breakpoints are viewport size, which is typically less than screen resolution. Check your viewport size here: https://whatismyviewport.com/
- Site
- Forum Problems & Feedback
- Scheduled for feasibility study Breakpoint behaviour review
