Bracing
Quick question, how much bracing is necessary for a small (35L) sealed enclosure made from 18mm MDF with a 30mm thick front baffle?
Will simply joining it and sealing it all adequately be sufficient for such a small box?
Thanks!
I've read every 8" should be braced...but technically you don't NEED any bracing, the sub will work without bracing. You just need to compromise between the internal volume the bracing takes up and an acceptable amount of resonance from the enclosure itself.
