Hi
can someone post pictures or give instructions on how to remove the back panel to get access to the subwoofer. I removed the 10 screws but the sub wire is too short and there is glue and a rubber gromet
Not a sin to cut the wire inside the cabinet (when the back is ajar) and later to add an extra length in there. Be sure to maintain the two poles. That leaves the grommet and sealing stuff intact and looking nice. If that works for you.
B.
B.
Sometimes wires are attached to the driver with snap-on connectors. You might be able to reach them, determine that they are the kind that can be pulled off, and pull them off with the back ajar. Be sure to wrap some tape on one lead so it goes back to same connection.
When I was a little kid I worried about putting stuff back together again.
Hey
thanks for your replies. I think I need to find a way to remove the gromit, maybe with a long nose plier so that I get some extra wire.
For some reason, there are either some clips or something as when I remove all the screws in the back panel, I cannot seem to be able to remove the cover
