Boss R2400d
Amp is in protect, no short found
SG3525
1: 0.000
2: 5.02
3: 0.013
4: 0.196
5: 2.089
6: 3.572
7: 2.072
8: 0.292
9: 5.46
10: 0.017
11: 0.002
12: 0.000
13: 11.92
14: 0.002
15: 11.92
16: 5.01
Any suggestions?
There is an optocoupler that has one output terminal going to ground and the other output pin for that same optocoupler section connected to the ON pin. Shorting those two pins together will enable the output stage. It may require an audio signal to start oscillating.
On the diagram, these are pins 5 and 6 of U7. Yours may be different.
Be careful The protection circuit is still bypassed.
