Bose Upgrade
You need an LOC, line out converter to do this:
BOSE Adapter
Expensive but about the best there is. Lots of other companies make them too such as Metra, PAC, PIE, DLC, & Accelle.
Next, you'll need a competent car audio specialist to do the hook-up. In fact, your search should probably start there as they probably will have a favorite brand they use regularly.
I'd also hunt down an FX45 forum. More than likely you aren't the first one to want to do this. There probably is an info-share out there you'll want to read.
speaker
