Boom Box TDA1524 Circuit Help
I am attempting to construct my first speaker and have a few very ignorant questions:
1.) What input types are allowed for the Lin and Rin inputs labeled in the schematic below? Would I simply use an auxiliary cord connection for both (ie connecting to an iPod/similar mp3 device?)
2.) Would the speakers be connected in series at the Rout and Lout connection points?
Here is the schematic:https://cdn.instructables.com/ORIG/FVB/RX3D/GY65QG9K/FVBRX3DGY65QG9K.jpg
Here is the TDA 1542 spec sheet:
TDA1524A Datasheet (click technical spec sheet on the product page)
Thank you in advance for the help!
You can connect the inputs any way you want. I've used alligator clips a lot. The wretched RCA is the hi-fi standard. XLRs work better but are overkill for small audio. Stereophone plugs/jacks won't stand hard use but are fine for home use, and natural if you live on iPod.
That chip is a volume+tone control. To drive a loudspeaker you add a Power Amp after it.
You could combine it with almost all amplifier boards. That depends on your speakers, deeded volume (=power) and your power source and speaker concept (Mono, Stereo, 2.1?). You should use a single-rail/single-voltage amplifier to make the power part much easier to realize.
A TDA7492 or TPA3116 would be a good choice if the battery has 12V (or more), for 5V a PAM8403 works fine.
Well, yes. The PAM8403 doesn't have adequate power and works a lot better with 4 Ohm, same for other 5V amps. The TDA7492 and TPA3116 are fine, the TDA8932 is a good option too (and extremely cheap). You can go for 12V or 18V (a lot more power).
Hey I am having issues wiring the control circuit, I bought several RAC cables, stripped them, and tried splitting them appropriately at the input and output but cannot get it to work. If I am trying to plug the aux cable into an ipod or iphone, what cable should I purchase to effectively split the signal to both the right and left input? What cable should I purchase to split the left and right outputs to the amplifier specified above?
Thanks in advance!
