jackinnj said:
Excellent! Thanks,
Jan Didden
interesting...... i'm doing some power amp output impedance experiments. looks like i've got some reading material on the subject. output impedance is one of the least written about subjects, both for opamps and power amps.
john curl said:About time you folks got updated about thermal feedback.![]()
Yes. I remember many years ago trying to explain to some otherwise bright people how an early JFET op-amp (LF256?) could appear to have negative gain in a standard test circuit.
Updated? Why? Have they finally eliminated the problem? 🙂
Edit: The topic was discussed quite extensively in this classic app note almost 35 years ago:
http://www.national.com/an/AN/AN-A.pdf
It doesn't really happen with discrete circuits in the same way, and these sorts of measurements don't show much, BUT Scott Wurcer has assured me that his parts are virtually perfect in this respect (at least, that is the impression I have gotten). Also, look carefully at Fig. 23 and the loaded transfer function of the LM725. This is what I have repeatedly questioned Scott Wurcer about regarding his AD797. Has he fixed the xover glitch as well?
Please Scott, tell me specifically if the thermal and xover problem is completely fixed? If not, how much different from the LM725 example? I am very serious, and somewhat frustrated that I might have to measure it myself, if I can't get any response.
better op amps in better topologies
Good article but it still doesn't explain why people wanting excellent performance don't just use Walt Jung's advocated buffered multiloop circuits when they want to avoid these probelms
remove the load, remove the heat, remove the thermal feedback from the input op amp altogether
the output device can be Class A for no crossover distortion
the output device can be really fast, have low output impedance to MHz (better RF ingress immunity?)
and for those who know how to design with it the output amp can add loop gain to the overall feedback loop at audio frequencies - even further reducing input op amp distortions by reducing differential signal at its input and Vswing at its (practically unloaded) output
Re: better op amps in better topologies
Cheers
I must have missed this in my travels. Got a link?jcx said:Good article but it still doesn't explain why people wanting excellent performance don't just use Walt Jung's advocated buffered multiloop circuits when they want to avoid these probelms
Cheers
What? Like this one?
http://www.diyaudio.com/forums/showthread.php?postid=1536373#post1536373
Naaahhh... Three legs good, eight legs bad 😀
jcx said:LT appnotes 18,21:
http://www.linear.com/designtools/app_notes.jsp
Walt Jung's Classic articles, lower half of page for multiloop/buffererd op amps:
http://waltjung.org/Classic_Articles.html
also my thread:
http://www.diyaudio.com/forums/showthread.php?s=&postid=512806&highlight=#post512806
discrete buffers can be a lot simpler than that!
cheapest would be resistive biased ef
for low parts count I'd look at the dual njm/jrc4556 with a pull down R for Class A bias if the 8 MHz gbw worked in the particular app without extra compensation components for the input op amp - wouldn't this 40 cent op amp outrage audio snobs paired in a multiloop with a AD797 or OPA627 input op amp
Walt usually shows the AD811 cfa which was good (but more probably because it was available in DIP)
more modern cfa op amp performance simply can't be touched in hobbyist level discrete designs - not too many can close feedback loops around 4 GHz transistors - but we can buy cfa op amps with -90 dB distortion driving 25 Ohms at MHz - I'm pretty sure we wouldn't have to worry about crossover distortion at audio frequencies
John, in case you missed my point. I assumed your point was that IC op amps usually do have thermal coupling problems and wanted to point that out to forum member who haven't realized it. However, I found the use of the term "updated" somewhat amusing, since there is nothing to be updated about. If people don't know about this problem they have simply missed what has been well known for many decades, which is why I linked to that app note. I just made a joke about your your phrasing (with no malicious intention). 🙂
Then, as you point out, progress seems to have been made in decreasing the thermal coupling problem and perhaps some modern op amps don't suffer from it at all.
jcx said:
Yep, been there, done that 😀
http://www.diyaudio.com/forums/showthread.php?postid=1528904#post1528904
And here's how the baby slews at +/-18V 1K load 😀
http://www.diyaudio.com/forums/attachment.php?s=&postid=1535651&stamp=1213127912
I work to point out such factors in electronic design. This is one that I didn't get around to discuss recently, but I read Solomon's article in 1974, when it was in the 'IEEE' transactions. I also had the test equipment made by Tektronix at the time to directly test for the effect of thermal feedback and xover distortion, and I ran lots of tests. However, my own designs did not have this problem, and I found the measurement was not useful for discrete circuits.
john curl said:I work to point out such factors in electronic design. This is one that I didn't get around to discuss recently, but I read Solomon's article in 1974 or so when it was in the 'IEEE' transactions.
And you should point it out, since most forum members probably aren't aware of it. As I said, I just made a benign joke about the way you phrased it.
The effect is hardly surprising since all amp stages share one small single piece of silicon.
a "must-read", definitely. good app note. i have one of the "orange and blue" NS books. even tells how to minimize thermal distortion in op amps. it seems not a lot of designers have read it... a good app note with information useful in power amp design as well.
yet there are still op amps and power amp chips with the same thermal problems, and they're relatively recent designs.....
too bad those of us working on discrete amps dont have the availability of multi-collector and multi-emitter transistors.......
BP was kind enough to omit competitor's devices.
I can imagine the folks at NSC trolling around people's desks looking for the oldest versions of the LM741 they could find.
Then again, with opamps like the LM4562 at 0.025ppm non-linearity available, can't we say we licked it for practical purposes?
Discrete circuits also have thermal non-linearities; even a few degrees temp difference inside an amp case (and often its more than that) makes the bias drift here and yonder. Admittedly, it's a lower (much) time constant, but again, are we supposed to go to discrete to overcome 0.025ppm? And can we at all?
Jan Didden
Jan Didden
- Bob Pease on op amp loading
