BMS 5N160 for a 3 way design.
Hello, I'd like to do a 3 way bookshelf, but I need ideas and your experience. I have this:
BMS 5N160 (91 dB sensitivity) 16 ohms 80-4000Hz
dome tweeter (92 dB sensitivity) 4 ohms 1300-20000Hz
I still haven't decided on the woofer.
What would you do if you had these speakers available?
Would you go for a 3 way bookshelf?
Would you go for a tower? For a MTM?
Would you throw everything and buy a commercial product?
Mainly I want to be able to make a normal LR setup, preferably where I can listen to music and maybe even mix some music, and preferably small in size, a pair of speakers either for the desktop or in a stands behind the desktop.
So far my best idea has been to do a normal 3 way active system, and to make the woofer side firing to maintain a slim cabinet. Since I have 4 of the BMS mid woofers, I've thought on doing them MTM but I'm not sure if this would work...
What are your thoughts?
Thanks!
