BMS 4547nd distortion at 10W compared to 4550/4552?
Post the distortion plots and we'll see what's up. I'm not sure if you are following what tbtl is saying, Displaying them +10 or +20 does not mean that the values are higher or lower, it just let's them display them on a smaller graph so the distortion isn't so far down. Hope that makes sense.
The BMS 4547nd distortion at 10W is marked +20 dB compared to 4550 / 4552nd which is +10 dB at the same power. Anyone know if it is true or typo?
Petter,
After looking at BMS old and new formats for displaying the same information, my vote is for a typo, there is nothing about the 4547 that should give it an even 10dB reduction in distortion at 10 watts over their previous drivers, considering the 1 watt distortion levels are nearly the same between them.
They also stop the 4547 distortion chart just above 10kHz so we don't see those upper lines meeting each other up around 19 kHz ;^).
If they used the same horn, the 4547 appears to have a few dB less top end than the 4550/4552nd.
Art
BMS 4550, 4552nd and 4547nd all have their distortion raised by 20 dB in these datasheets.
Petter Persson was writing about the 10 watt distortion figures, which are raised only +10 dB in the 4550 and 4552, but are claimed to be raised +20 in the 4547, as can be seen below.
