Bluetooth + amixer volume control
I'm using the following .asoundrc file:
Code:
pcm.!default {
  type plug
  slave.pcm plugequal;
ctl.!default {
  type hw card 0
ctl.equal {
  type equal;
pcm.plugequal {
  type equal;
  slave.pcm bt
pcm.equal {
  type plug;
pcm.bt {
    type plug
    slave.pcm {
        type bluealsa
        device "32:00:00:02:84:BD"
        profile "a2dp"
        delay -20000
I cannot change the volume in the Bluetooth device using amixer. I tried:
amixer sset PCM 0% -M
amixer -D default sset PCM 0% -M
amixer -D bt sset PCM 0% -M
The volume doesn't change.
Thanks!
alsamixer shows volume change for PCM when I use:
But the volume level in the Bluetooth speaker doesn't change.
If I run:
alsamixer -D bluealsa
it shows:
This sound device does not have any controls.
$ amixer scontrols
Simple mixer control 'PCM',0
$ amixer controls
numid=3,iface=MIXER,name='PCM Playback Route'
numid=2,iface=MIXER,name='PCM Playback Switch'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
