Hi guys,
recently I was using one of my Bluesound units (the power node n150) and the internal fuse from the psu has blown! I've replaced it and the same keeps on happening. So most likely a psu issue. Can anyone advise on this?
regards
regards
I don't belive anyone here is psychic 😁 There is obviously a short somewhere, which may or may not be obvious. You need to take it apart, try to get schematic, multimeter and search for what caused a short if it's not seen by eye.
Agree. I've just isolated the problem to the psu. But the aim of my post is mainly to have some insight from other users with similar problems because if you Google around you can see on the bluesound support group several complains on the psu. I expect that there is a trend of a specific issue.
thank you
thank you
