Blues Junior sounds muffled
Hello! My Blues Junior (green board) sounds muffled/distorted even with low gain. Tubes are OK (tested with a tube tester and swapped with good ones). Bias seems to be fine. Checked resistors, caps, speaker, and seems to be everything fine. I am getting crazy! Any ideas?
these amps have input jacks that are directly soldered to the pc board, if there has been any mechanical stress from a jack cord pull or it's been knocked over on it's face with a cord plugged in it's quite likely it's developed cracked solder joints.
Thanks for the hint. How do you check them? I measure continuity between each resistor terminals to check if the resistor has blown, but I am not sure if it would be better to unsolder them and measure ohms as single components. What do you think?
Bingo!! The R35 and R36 resistors were damaged. No visibles signs of that, just used the multimeter to measure ohms and both were in open circuit. Besides, the previous owner had installed 1/4 W resistors, and the schematic requires at least 1/2 ones. Installed new R120 1 W resistors and the amp almost blew up the windows! Thanks everyone for your help!!
