Blue 9643X dual pot ??? quality replacment ?
I am a volume imbalance on my pre amp which seems to be getting worse, guess the volume pot is the prime candidate ...... does any one recognise this part
blue board mounted dual channel pot with the following numbers written on the side ?
01A2AB28D1515
10K 10K
Mexixo 9643X
If so any suggestions for a quality drop in replacment?
also the boards have a lot of TL072CN op amp, these must be 10+ years old now and better quality alternatives recomended?
Many thanks for nay help or suggestions
( ps I am not technically knowledgable so please keep it simple)
Ian
01A2AB28D1515
10K 10K
Mexixo 9643X
Bourns pots, as they seem to be, are good pots.
Abut the TLO72CN, it's difficult to suggest anything without having a look at the schematic. Do you have it?
Those chips are from the '70s, and there are better options now, but it will depend on the specific application. Several discrete parts around them, like capacitors and resistors might have to be upgraded too with better chips.
In fact I'd start an upgrade improving the power supply and eliminating all electrolytic and ceramic capacitors from the signal path. Then go for a chip upgrade.
Carlos
Hi Carlos,
many thanks for your reply, as I understand it there were only about 14 of these units ever made in the late 1990s so I guess chances of find a circuit diagram is very small.
The Op Amps appear to be linked to the various input and control switches. Several component groupings are repeated for each switch. I will see if I can find somewhere to post a photo. Its a very neat and tidy board.
I would rather not make to many difficult to reverse mods - as it sounds and looks rather good.
TL072 is a FET input op-amp. If you were to replace it, I would suggest using another FET input amp, not a bipolar. There are subtle but important differences between circuits designed around a FET vs. a bipolar input op-amp. Most audio op-amps are bipolar. The Burr-Brown (TI) OPA2604, OPA2134, and OPA2132 are all FET input and are considered quite good. The TL072 is not a fast op-amp so don't choose a fast (high GBWP) op-amp as a replacement or you might face oscillation issues. I see that the op-amps are in sockets, which makes it very easy to "try and see".
Even if you don't replace them, pull each from its socket and re-insert it. The pins scraping against the socket connections will remove any corrosion that might have built up over time. I have in the past fixed problems using this simple procedure. This may in fact fix your imbalance problem.
