Blown amp worth fixing?
The outputs are connected to the speaker terminals, use a DMM to find them if you can't see the traces. They will be on the sink. Look up the number on them see if they are cheap to buy. Some are, some not. If you start it carefully you should not blow them again if something else is wrong, but it might only need those.
