I want to add bleeder resistors to my power supply so the caps are discharged when the amp is powered down for safety purposes. Do I run the resistors between the + and - on the DC out to the amp?
Thanks in advance
Thanks in advance
Yes.I want to add bleeder resistors to my power supply so the caps are discharged when the amp is powered down for safety purposes. Do I run the resistors between the + and - on the DC out to the amp?
Thanks in advance
You need to choose the resistor values (ohms, watt rating) to discharge the PS caps to a safe level in a reasonable time, but not 'load down' the PS by adding a significant current draw during normal operation.
There are online tools/worksheets for doing the calculation or you can do the math 'from scratch'.
The simplest circuit design is also the easiest to remember: just connect a bleeder resistor directly across the terminals of each electrolytic capacitor.
My own preference is to use flameproof resistors rated for 1 watt, and then choose a resistance value R such that the power dissipated in the resistor will be (1/2) watt or less. So for example if the DC supply voltage is 54 volts, I would choose R >= 5.83K. Namely, 6.2K with 1 watt rating. Personally I don't care whether the bleed-down takes 10 seconds or 120 minutes. Other people may have different opinions about this.
