Bipolar output stage prefers capacitive or inductive load?
Hi Paul,
The less reactance, the better for any amplifier. This is especially true of tube amplifiers. The solid state kind are usually less affected by phase angle, but odd things can happen.
Capacitive loads are about the worst for a solid state amp. You effectively reduce the high frequency feedback voltage when things get out of whack. Not good for stability sometimes. Inductive loads won't hurt stability, but the excess dissipation in the output stage is not welcome.
-Chris
Hi Paul W.
When an amp drive a reactive load some precaution can be made.
With capacitive load you should check the stability of the amp.Connect an audio generator and a scope and check the overshoot and ringing on the signal.If instability is produced you should change(or add) a Zobel network.
When a large inductive load is driven you must to protect the output transistors with two diode connected from the negative supply and speaker output and from speaker output and positive supply.
Obviously the betterfor all the amp(tube or solid state) is resistive load.You can also compensate with a RC network the inductive loads
The suggestions of Anatech and Darkfenriz are also excellent.
Cheers
Vittorio
Hi Vittorio,
Paul is designing a speaker. We have to worry about what it does. 😉
Paul W,
Slightly inductive is excellent. It should be an easy load for most amps then with minimal phase shifts. Good choice!
-Chris
Hi Vittorio,
Well, let's see what he does. That is always a concern.
I had a guy blow up an Adcom GFA-555II twice. He made his own sub crossover. I asked him to bring it in after hearing the crossover was really hot. The first element was a 220 uF bipolar cap across the input. :bigeyes:
-Chris
A capacitive load adds a phase lag to the feedback voltage.
According to D. Self, lowering the impedance of a speaker using some RC or RLC networks to make it resistive is not a good idea : the amplifier will have to deliver more current which means more distorsion. A good amplifer does not suffer from instability with usual loads.
Hi forr
this is not always true.
For different reasons some amplifiers with a large amount of NFB or some tube amp do not like reactive loads.
When compare the distortion on a tube amp that drive a inductive load with the same load compensated with a RC network we can see that the distortion decrease.Test this in order to believe....If we speak about sound we can discuss to the infinite 😀
Cheers
Vittorio
Hi d3imlay,
220uF is not a reasonable load for any amplifier.
A 45 ° phase angle on your load would be a stressful test for an amp. Resistive loads are the most common, I've heard of people adding 0.22 uF across and 8 ohm dummy load as well.
Really, you just have to check your designs into a standard load and provide safety margins. The 0.22 uF cap is more for testing stability.
-Chris
