Bias filtering
Er...
*choke*
Just how much current you intending on drawing from this ******* bias supply anyways?!
Oh... per amp... still 5x too much! ;O)
Besides, bias is applied through a grid leak, the other end of which is almost always connected to a low impedance triode. In fact, you can run through the voltage dividers thus represented and find exactly how much ripple actually appears _at the grid_. Then for extra points, determine the CMRR of the PP output stage! (If...that happens to be what you are biasing..)
Tim
Er...
*choke*
You mean you DON'T weld with your bias supply?!
Apparently, if I use tantalum, 125x too much!
I think I see what you're saying, but... since the grid can't emit electrons, theoretically anyway..., whilst it's biased negatively it should have a very high resistance between it and the cathode shouldn't it?
"The grid of a tube normally presents a very high impedance load to the driving source when it is biased in the negative region." Aiken of Aiken Amps.
