• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
BHC Capacitor Clearout
I'm clearing out a whole bunch of old(ish) BHC capacitor stock. All these are 2004/2005/2006 stock so should be absolutely fine.
Any questions please email: matthew.campbell@camcol.co.uk
ALL SENSIBLE OFFERS WILL BE CONSIDERED (and probably accepted!)
Also email me if you need to know cost of postage, as some of these are obviously pretty weighty.
Part Number Capacitance Voltage Description
5x ALC10A1125BF 16000 25 25x50 PCB
6x ALC40A1050DF 12000 63 12000uF 63V, Ø35x50, 105°C
19x ALC10S1074DL 10000 80 10000uF 80VDC 85°C Electrolytic Capacitor Slit Foil, 35x80mm
28x ALC40A103CC035 10000 35 30x35 Solder Tag 105°C rating
4x ALC40A103AD016 10000 16 10000uF 16V, Ø22X40, 105°C
6x ALP10A332BB040 3300 40 30x45 PCB
15x ALT22A332AA040 3300 40 3300uF 40V, Ø25X35, 85°C
76x ALP30A1012DX 2600 200 2600uF 200VDC Electrolytic, -40+85°C, 40Ø x 85mm, PCB solder connections
2x ALP22A222DF200 2200 200 40x105 PCB
6x ALC10A222BB063 2200 63 2200uF 63V, Ø25x30, 85°C
36x ALP20A222BB063 2200 63 2200uF 63VDC Electrolytic -40+85°C Case size 30Ø x 45mm, PCB solder connections
17x ALP20A222BB063 2200 63 30x45 PCB
3x ALP20A152CB100 1500 100 1500uF 100V, Ø35x45, 85°C
10x ALP20S1008BB 1100 63 1100uF 63VDC 85°C Electrolytic Capacitor, 30x45mm Slit Foil, PCB Mount
4x ALC10C102EL450 1000 450 40x80 PCB
2x ALC40E1005EL 700 450 40x80 PCB
3x ALC12E681EF450 680 450 40x50 PCB 105°C rating
6x ALP22A681DE385 680 385 680uF 385V, Ø40x75, 85°C
14x ALC10A681AB100 680 100 680uF 100V, Ø22x30, 85°C
4x ALC10A511DF415 510 415 510uF 415V, Ø25x50, 85°C
20x ALC10F1045DH 470 450 470uF 450VDC Electrolytic -40+85°C 35Ø x 60mm, PCB solder connections.
50x ALC40CA41DF350 470 350 470uF 350VDC Electrolytic, -40+105°C, 35Ø x 50mm, PCB solder connections
6x ALT11A471CB160 470 160 35x45 PCB
2x ALT11A471CB160 470 160 470uF160V, Ø35x45, 85°C (studded base)
7x ALC40A330AB450 33 450 22x30 PCB 105°C rating
I need 6x 10000uf 80V caps to recap my subwoofer amp.
Please can you comfirm the dimensions and pin type of your ALC10S1074DL caps.
How much would you charge for 6x caps including delivery within the UK?
Many thanks,
James
Many thanks,
James
James,
How does £5 each for six pieces and £5 for postage (ie £35 total) sound?
I will dig out these parts and confirm pinning and dimensions (probably tonight or tommorrow a.m.)
Matthew
maxlorenz said:
How much would you ask for the 6x ALC40A1050DF 12000 63 12000uF 63V, Ø35x50, 105°C?
Please quote airmail shipment to Chile, South America.
I also could use some ALC40A103CC035 10000 35 30x35 Solder Tag 105°C rating...
Thanks,
M
ALC40A1050DF £5 each
ALC40A103CC035 £3.50 each
Postage to beautiful Chile will be £33 for the 6x ALC40A1050DF and a little more (maybe £39) if you add some ALC40A1050DF caps.
Matthew
Predator864 said:
ALC40CA41DF350
ALC10F1045DH
ALC10A511DF415
ALP22A681DE385
ALC12E681EF450
ALC10C102EL450
ALP20A222BB063
ALC40A1050DF
Prices ?
Ship to Romania or Chester UK ?
ALC40CA41DF350: £2 each
ALC10F1045DH: £2.50 each
ALC10A511DF415: £2 each
ALP22A681DE385: £3 each
ALC12E681EF450: £3.50 each
ALC10C102EL450: £6 each
ALP20A222BB063: £1.50 each
ALC40A1050DF: £3.50 each
I'll discount a bit if you want to buy lots....!!!
Shipping will depend on how many you buy, but will be charged at cost.
