OK, this is for wire believers only. What do people like for wiring a DC supply and why-I am completely open to suggestions.
Solid Core?
Stranded?
Gauge?
Teflon dialectric?
Polyethylene?
Copper?
Silver?
Silver plated Copper?
This case is 15 VDC and about 200 mA, open for discussion...
Solid Core?
Stranded?
Gauge?
Teflon dialectric?
Polyethylene?
Copper?
Silver?
I do not think it matters much at that voltage and current. If the cable is of any length attach an electrolytic and a .1 at the receiving end. E
I found some tin plated copper stranded teflon insulated 18 ga at electronicsurplus.com, I'm mostly using that these days. Silver plate seems required by ROHS, which the distributors sell exclusively, I'm not buying any more of that unless I can't find something cheaper. My last roll of 22 ga stranded teflon ROHS alpha wire was $.60 a foot, and was stolen at the shipping dock (substituted by something cheap that weighed 2 pounds) and had to be replaced by the distributor. At currents above 4 A I use 16 to 10 ga surplus stranded PVC insulated THHN (copper no plate) building wire. Works great in crimp connectors, hard to solder.
If it mattered at all, it might depend on what you're powering with the supply in question. But the best wiring might be none at all, with the supply right at the point of load. However, if you'e a "true believer", then you already know that the most-expensive solution must be the best solution.
Respectfully: your response makes an assumption. I do believe that parts selectiony matters. I find the prevalent view at these forums which claims that circuit design is all that matters rather closed minded. Certainly circuit design is of primary importance, but layout details, parts selection, mechanical design/vibration control, all will impact final sound quality.
I make no assumptions about the "most-expensive" solution being the best; believing that wiring choice can affect sound does not pre-suppose that the most expensive wire will sound best. Certainly keeping the wiring as short as possible, as well as appropriately routed is good advice, but the topic is wire SELECTION for DC supply wiring.
In this case, the supply is powering a class A, discrete, balanced line level circuit.
Of course you are correct. And I have to apologize. I was thrown off when I read "for wire believers only".
The most important properties that I can think of at the moment are low inductance and smallest enclosed loop area (for resistance to EMI). A shielded twisted pair comes to mind. Using all Teflon insulation should be best.
- Design & Build
- Parts
- "Best" wiring for DC supply?
