Hi i'm wanting to make a portable speaker, but i'm not sure how to power it. I want to use this this 2.1 2x50w + 100w bluetooth amp to power it, with 2 45w speakers and a 40w bass driver. The amp says it can take 12v-24v. I was looking at this 12v 3a battery pack. Its the perfect size for what I need and is a good price, but I wasn't sure if it would be enough to power everything. Is there any better way to power this?
The amp probably uses a tpa3116 or 3118 circuit. You can check the data sheet - 200 w is very optimistic - only possible with max supply voltage and 2 ohms bass driver. So, providing only 12 v you will have less power (around 25% of maximum) but also less maximum current, which is good and could be perfectly ok for a small box.
I built a portable bluetooth box with a similar amp and a power tool 18 volts 4Ah li-ion battery that gives plenty of volume and lasts nearly for ever ...
(... And welcome to the forum!)
Thanks for the info. I like the power tool battery idea. I can get a 24v kobalt battery and get an adapter. A 1.5Ah or a 2.0Ah would be best because they are smaller. This is the adapter. Do I just connect the wires to a plug like this and then im good to go?The amp probably uses a tpa3116 or 3118 circuit. You can check the data sheet - 200 w is very optimistic - only possible with max supply voltage and 2 ohms bass driver. So, providing only 12 v you will have less power (around 25% of maximum) but also less maximum current, which is good and could be perfectly ok for a small box.
Maybe, but you´ll have 15 minutes running time, as mentioned above.A 1.5Ah or a 2.0Ah would be best because they are smaller.
Divide amp consumption in A by battery A/H and you´ll get running time.
Since advertised values are optimistic, halve them.
With 12 v and 6Ah?but for only about 15 minutes
I think it will last very long, if not driven constantly at the limit.
I would think so. Just make sure the polarity is correct!Do I just connect the wires to a plug like this and then im good to go
My post states using full power. Naturally it will last longer at lower levels, but then what is the point of using amplifiers of this high power!With 12 v and 6Ah?
A TPA3116 is what I'd consider low power, and efficient. Perfect candidate for a battery powered bluetooth speaker imo.but then what is the point of using amplifiers of this high power!
Let's be realistic - A TPA3116 will make about 2x10W into 8ohm loads or 1x20W into a 4ohm load with a 12V powersupply. The amps that have a stereo output AND subwoofer output generally have two TPA3116 amplifiers in them so you get 2x10W + 20W.
Running it at 'max volume' on music, even clipping slightly, you won't even consume 20W per amp from the battery but let's assume you do.
12V * 6Ah = 72Watt hours, so it will last close to 2 hours. Practically I think you will see more like 3-4 hours out of it because music is not a sine wave test tone.
The 3A output capability is probably pushing things a bit but I think it will be ok - worst case you might melt the barrel plug running it at full tilt for a long time. If you could find a battery with a 12V @ 5A capability that would be safer.
- Design & Build
- Parts
- Best way to power 200w amp for portable speaker?
