Best *tiny* full range driver overall?
Hi guys. I have a new project in mind. One that would fit a tiny "line array" in tight spaces. On this one efficiency would not be as important as my last build which is a pa. This will be used in small spaces like cars etc. Accuracy will be the key, cost may be a factor, 2" or less is paramount. What do you guys think?
Well....I am within 4 feet of my small line array stage rig, walk away and still hear about the same (excellent) fr balance, without notable hf variation, I would assume that a small full range "array" in a car or rv crossed over to hidden sub will also work well. Worth investigating imo.
I find the Tymphany TC6FC00-4 to be exceptional in detail and the Neodymium magnet makes transients really shine. I cross them over sharply (24dB/octave) with an electronic crossover at 300Hz, so not strictly full-range, but wide-range. Good luck!
I thought comb filtering would not be an issue if drivers were within 1/4 wavelengths of highest frequency. On a 2" driver we are getting pretty close to coupling everything from 10k up are we not?
With a pair of 2” C-C pushes ¼ wl up well over 20k, but in an array — assuming ear is at the middle driver — C-C is 2” x n/2 so combing will happen at lower frequencies will it not?
dave
dave
I was thinking no comb filtering from 10k down I meant to say. Probably thinking 9 drivers per stick. Depends on the driver I go with. Pretty amazed at what my little 9 unit 3fe25 stick is doing combined with a 12" car sub in a 1 cubic foot sealed box is doing.Incredible spl actually.
Way more than my Mackie units were doing and clean clean clean, deep deep too.☺
