Hi folks which resonansefrekvensies are desirable for a guitar driver. Im thinking for semiclosed back enclosure.
Cheers!
Cheers!
With 6.5 inches I would try to stay below 100Hz. Have a look at Jensen MOD15 - not super powerful, but fine overall sound.
There are some very high efficient 6.5" drivers on the market - with a resonant frequency of 250Hz or more - useless for guitar.
Thanks for suggestions guys! I have some 7 inch and I found out they have res. Freq 40hz. Do you have ideas how to raise the fz? of a driver. If it cant be done, I have some other that I need to measure. Cheers!
The resonant frequency goes up if you mount the speakers in a sealed (not open, not ported) box. But raising it from 40 Hz all the way to 80 Hz would have other consequences, it will make the bass response peaky.I have some 7 inch and I found out they have res. Freq 40hz. Do you have ideas how to raise the fz? of a driver.
I'm not sure you need to raise the resonant frequency, though. I suggest just trying the 7 inch as it is - the guitar doesn't go down to 40 Hz, but at low power, it doesn't hurt anything if the speaker does go that low.
(At high power, the speaker might potentially be damaged because of the soft suspension that allows the resonance frequency to be that low.)
One of my home-made speaker cabs has two 8" speakers in it, one with a 60 Hz resonance, one with 130 Hz. The 130 Hz one sounds better, to my surprise.
Later I realized that even though the low E string on a guitar is tuned to 83 Hz, most of the energy in the vibrating string is not in the fundamental, but rather in the 2nd, 3rd, and higher harmonics. So not much bass below 166 Hz, actually.
-Gnobuddy
The Q of the speaker has as much if not more impact on how a speaker sounds in the low end. If the speaker doesn't have the top end it does not matter what the frequency responce or the Q is.
I'm thinking this one is even better:With 6.5 inches I would try to stay below 100Hz. Have a look at Jensen MOD15 - not super powerful, but fine overall sound.
https://www.eminence.com/pdf/620H.pdf
- Live Sound
- Instruments and Amps
- Best resonance freq.. for guitar speaker driver
