Looking to build a very interesting design, need to know the internal volume from this triangle shape box. Also with the ports, anyone have a good cad/3d software?
Most (all?) loudspeaker enclosure calculation programs allow to set simple internal volumes and maybe one main dimension only (I like hornresp). You would need a cad software or pen and paper or calculator and the respective formula to calculate the volume of a triangular box.
If you need a simulation of complex enclosure plus port you would gave to use a fem- simulator (akabak, abec, comsol, ... no clue if there are free versions).
Surface of a triangle, by the way:
base * height / 2
base * height / 2
