I have already built the half chang for the Pioneer B20s. I want to try something new for these speakers. They are already modified with phase plugs and puzzle coated. What enclosure would give the most bass output from these drivers? Would BIBs be the best way to go? Thanks
I know my qtc .577 (6ft3 sealed, no fill) huge box (3' tall x 2' wide x 1' deep driver on top middle edge) sounded much better than my qtc .707 sealed (1.7ft3 with a little fill, dual walls with sand). Baffle step and lack of back pressure on the cone doing midrange are my thoughts..................
The big box run by itself or with a 24db LR crossover to a piezo was very good.
Most bass ?
Well, a ported will lower driver excursion (always a good thing) but can unload below tuning frequency as well. Maybe a tranmission line would work well. I think it was duke that said a ported always blind tested better compared to his more favorite sealed when designing a speaker.
Norman
Most bass ?
Norman
Consider a MLTL, I built one several years ago for my B20's, not too huge, but nice bass. Can get down into the 30's no problem. To estimate the size from memory I guess it at 48" high x 10" wide x 15" deep.
PJN
PJN
I heard a corner loaded enclosure will get the best bass response especially if you have thick corner walls. My house was made with 1" thick plaster walls so vibration won't be an issue. I love the B20 drivers so much that I am completely satisfied with them. I am not tempted to go with fostex or Tang Band since I heard the B20s give the best bass response out of any 8 incher. They have more bass and sound less muddy then my 12" hammer dynamics speakers in a half chang cabinet! This is still hard for me to believe sometimes. Thanks for your responses.
Simple pipe horns such as the BIB is a step in the right direction, but the answer will always be a freaking huge BLH with a cut-off based on the driver's specs (~8-10 Hz for the B20) that will completely overpower the driver's mids/HF output and potentially reduce your plaster walls to dust, but I seriously doubt this is what you really want. The maximum practical bass output then is based on how large a BLH can be tolerated and what the room's gain curve is.
GM
>>> The maximum practical bass output then is based on how large a BLH can be tolerated...
Tolerate is a good word here bc i actually like the B20 best in a small sealed box sitting behind me at the office with a rear firing tweeter. It's all i could tolerate in the room. The Half Chang may be the best compromise there is for this driver but i never heard it... but it looks great and i bet it performs great too. Nelson's transmission line may be best too... or a BIB tucked in corners may be best if you can tolerate the size... and the bass it will produce. It may not take any more floorspace than the Half Chang or the transmission line. I even liked it very much on Open Baffle with bass and treble support.
I can't imagine a large pipehorn for B20 having a lot of clean power - here's a direct comparison of B20 vs the earlier version of Eminence B102 in a "Druid" sized pipe with floor vent each at the same drive level, each with mic and speaker in the same spots - look at the levels at 50Hz for the same input drive - a MLTL might be a good compromise - or go OB with 15 or 18 - -maybe I'll buy a fresh B20 to try
Thanks Freddi, i wonder if that downward trend from 1 - 3khz is the main reason for them sounding so mellow? Thanks for posting the chart.
Godzilla
Godzilla
Yeah, my experience with a much earlier version of the driver was in a ~2 ft^3 reflex tuned to ~40 Hz. Backed up to wall and driven with a PP amp it handled most of the vinyl, tapes of the day. Rick Wakeman's The Six Wives of Henry VIII and DSOTM did them in at a party though.
Agreed, the cobbled together OB I posted about on the other FR forum back when these were (re)discovered showed a lot of 'el cheapo' potential coupled to a mass loaded B20 woofer + piezo horn nestled between them. Still have the drivers and hope to revisit/optimize this system one of these days.
GM
try the B20 in the Hedlund cabs with an inverted dome tweeter and your Shadow SW. wow on some ok program music and on some good program music - really wow.
but the Hedlunds are 78" tall!
wonder what a pair of these would sound like with a flared exponential horn?
I am pretty much satisfied with the B20 in the half chang cabinets. I feel these speakers don't lack anything. I could buy "better" drivers, but I am planning on enabling the drivers and the cabinet also. If I screw up the enabl process then it isn't as big of deal. I simply love the unfatigued sound of the B20s. I am afraid if I upgrade that I won't get the mellow and smooth sound. I already have the Silver Iris speakers which offer more detail then the B20s, but they aren't as mellow. I probably will sell these. I guess I have narrowed down to two enclosures. The nelson and the BIB. Maybe I should try making both on flake board and then compare to the half chang. Does the full chang sound that much better then the half chang? The goal behind this project is to produce the best speaker for the money. Thanks for your input!
I like Nelson's TL design quite a bit. It's big but does dig very deep.
Pass The Bofu Building a transmission line cabinet for the Pioneer 8-inch full range driver. Article By Jeff Poth
that's a nice size and just about the same as a Fostex BK20 - can it sound reasonably solid and not too compressed on lower drums? I ran B20 in recycled EV Innerface B boxes retuning the PR on RTA - seemed to compress and modulate (?) I've seen it go out of control in a Druid pipe at higher levels on drum solos but I like things perhaps louder than some. At its price point its a keeper for some apps.
Well, I think you and I have the same sort of standards. The Druid pipe doesn't load nearly as deep and low as the TL. I didn't have any major complaints with big drum sounds, but that was all contextual. Naturally it doesn't have the impact of a PA style woofer in an even bigger box. At typical levels it has only moderate "politeness", but it tends to overload gracefully, so it isn't a huge dynamic contrast speaker in absolute terms- vastly better than many though.
yeah - fwiw the fake Druid pipe worked very well with the earlier B102 with regards to power handling and output - I've already ~50 speakers crammed in a small house
Yeah, for the money they rock. I'd love to hear them in a cab that produces real bass. Fostex and others may sound more detailed but not as mellow. I never miss the detail with the B20 until i compare it to something else.
I must have just as many sitting on shelves in half open boxes. Need to organize them and build. Problem is, i keep changing my mind on what to build.
Only 50?
I've at least 500 🙂 Probably 500 too many.
Gonna give some away at this years diyFEST.
dave
dave
I'm afraid to count that was two rooms of cabinets - then packed shed - then there's all the raw drivers - WBAL BetsyK might work in Nelson's B20 t-line - just got mine back rebuilt (thanx PJ) and hot off the truck qts~0.5 and fs~50
Only 50?
dave
I'll post myself there.
I recently cleared out my speakers. Half of them were rubbish or blown. Then I go past a second-hand shop with a pair of Celestion 2-ways outside....
Anyway, back on topic...
- Full Range
- Best Enclosure for Pioneer B20
