Best driver to cross high?
Hi all,
Dayton 12 HF's are back in stock at PE, so now, I'm about to order two. They'll be powered by a Behringer EP2500, and I'd like to cross them over higher (say 250 Hz), very similar to the pro bass bins I'm used to seeing.
Anybody have any other suggestions as to a potential driver I could use to cross high? I want to reach LOW for movies and great (mid-)bass for music (system to be used 50/50 for both).
Thanks!
mmmmm saturated fattttssss.
The dust cap seems to be the largest undamped surface of the cone, the outer piece being well damped by the soft rubber surround. I used elmer's past glue because the only sovent it needs is water so it is easily reversible. If you wanted to be audiophile about it you could use long fiber wool felt or something... "The very same felt as used in a steinway grand!"
This probably at least helps to control the roll off quite well.
