Best configuration for this subwoofer and box?
Due to certain circumstances, I'm getting a roughly 100 liter box (minimum) preloaded with two Peerless 831727 10" woofers. Assuming the box is sealed, I was planning on running them parallel with a plate amp from Rythmik Audio. According to winisd, I get output pretty similar to other sealed subs that don't use EQ. Is there a better way for me to set these up? I've tried some sims with winisd and it seems isobarik is the only other config that will work with decent phase and group delay, but it will be difficult with the premade box. Any suggestions? I don't need bone crushing volume, I will be listening in the nearfield. I also only *need* extension down to the low 30's to be happy.
