i know there are a few other people on this forum from bristol, and i wondered if anyone knew that cheapest place to buy 20-25mm thick MDF sheet. larger than 800x800mm.
Thanks in advance for any help,
Matthew
Matthew
I don't know about if it is the cheapest but I buy mdf from Avon Plywood in Keynsham, they stock mdf up to 50mm thick and in sheets up to 10' by 5'. You would probably have to buy a sheet so get them to cut it, 30mm mdf is very heavy! Their cutting is accurate to the mm.
If you are making speaker cabs consider making them out of two layers of 12mm mdf. its an easy way to make rebated joints ( just cut the inner layer smaller) and you can use a rubber based contact glue to get some extra damping.
hope this helps
khush
www.avonplywood.co.uk
hope this helps
khush
khush said:I don't know about if it is the cheapest but I buy mdf from Avon Plywood in Keynsham, they stock mdf up to 50mm thick and in sheets up to 10' by 5'. You would probably have to buy a sheet so get them to cut it, 30mm mdf is very heavy! Their cutting is accurate to the mm.
hope this helps
khush
Yes, i am making a subwoofer. i have access to a workshop, so i can cut it myself.
Hi
B&Q believe it or not were the cheapest i could find.
18mm thick 8foot x 4foot sheet for £9.98
and they have a free cutting service if you go to the big one in Filton
HTH
HTH
Solid wood, Clarks on the feeder rd is consistently cheaper.
B&Q and Selco can be pretty cheap for sheet goods. 18mm maximum though.
Avon Plywood are simply amazing, and although a few quid more, there cutting service is so incredibly accurate (I think there Holza beam saw is about £120,000). Usually £10-£15 to have every piece cut exactly right is well worth it. I recently had some Walnut veneered panels cut and lipped, from arriving at the workshop, had a walnut clad box together within an hour.
Their Birch Ply is so beautiful, im working on building a chest of draws as a high end piece of furniture. If I was to build a sub, 18mm Birch ply would be my choice, either left natural or stained.
Louis
Louis
