Best bias for 6cg7
Hi Allessandro,
6CG7 is a 6SN7 in a noval envelope (slightly derated plate Pd, but this doesn´t matter for your app).
Thus, any Schmitt splitter designed for 6SN7 should give suitable operation point suggestions.
For an example, see p670 of RDH4 (ECC32 = 6SN7).
Tom
Hi Giaime,
regarding ECC32 = 6SN7,
at least the german "Röhrentaschentabelle" says so.
But you are right: Glancing over the specs sheets, data is not identical, I agree. But not very much off either.
For the Schmitt splitter app under discussion, the mentioned RDH4 example still should give a good starting point for 6CG7/6FQ7 or 6SN7 usage.
Tom
