Beryllium expanded usage?
Why is there not at least a 6” BE midrange? Is it too brittle? What about beryllium formers? Apparently it had amazing temperature related properties? Is it magnetically inert enough? The BE former could theoretically be literally part of the BE dome or cone (shape and contours and thickness is also important but there’s a company in LA called LA Guage that has extremely impressive abilities to mill it and a thin dome with any thickness and an extremely thin former could probably also be worked out but those are so thin i’m not sure if humans can machine .001mm or whatever it is either way as a number of stiffened foils which must be possible, this could change things what’s going on? I know how lethal it can be but this clip shows some great promise
