Afternoon chaps!
I've been given a Beomaster 5000, which powered up fine, all lights came on etc ok.
However, no sound came out of it! When you plug in a speaker there was a crackle from the speaker, then nothing.
After trying a few things and having it powered on for a bit, I noticed a small wisp of smoke coming out of it near the input tray.
So, I thought what the hell and opened it up.. after a bit more plugging in and dismantling I narrowed the smoke down to R38 and r39 burning away merrily. I've had a quick trawl and can only find that this is common ish, but the problem is possibly deeper than the resistors. They are on the pre-amp side as i under stand it!
Looking for any help you may be able to give! Layout diagrams, experience of this unit etc! Not sure what to do.. I have limited soldering expertise/ experience but am keen to learn and see this as an opportunity to do so. Am I mad or shall I just stick it on Ebay? Is it worth fixing?
EDIT. At least I've found a copy of the manual with the resistor values. Tempted to replace them with wire to see if that works.. is this a bad idea?!
http://beophile.com/wp-content/plugi...oad.php?id=145
Cheers!
James.
Cheers!
James.
I have no experience with the Beomaster 5000, but many moons ago I repaired a few Beomaster 3000, 4000, and Beocenter 3000 for myself and family members. They all had schematics in a brown envelope glued to the bottom panel, which made debugging a lot easier. I never had one I wasn't able to repair. I was in 7th or 8th grade at the time... 🙂
~Tom
~Tom
replacing resistors with wire is just going to cause more damage. if a resistor is burning, it means something is trying to pull too much current through it.
A PDF-formatted service manual is available for free download:
Take care! 😎
Take care! 😎
