I am looking for a device to raise the input levels into my DEQ & DCX 2496.
Several options are available including a Pre Amp, Di Box, and the Behringer Ultramatch Pro SRC2496 .
Both the DEQ & DCX are linked via AES/EBU, so I need a device that will convert the consumer levels to pro with out having to build/construct anything, basically I am looking for an off the shelf solution.
Dick
Dick
If you're willing to build something yourself it's an easy/cheap solution. If you need something off the shelf it's going to cost a few bucks. The ones you mentioned should work. There's also this:
http://www.gainesaudio.com/spec444.htm
He used to make a two-channel version of this that was cheaper, but I don't see it listed on the website anymore. Maybe a phone call?
You could also use transformers from somebody like Jensen.
Davey.
Davey.
Thanks Davey
The Gaines Audio 444 is exactly what I am after but @ US$249 plus shipping, it would cost me as much if not more than the Behringer unit.
The trouble with making a unit, is I doubt whether I could make it to look good in my audio rack, but then again, I suppose looking at the Gains Audio and other units it could be placed behind the rack.
Would these be used in a passive environment?
I was looking at the Behringer site, and thought this may be a good option for anyone using the DCX2496, as this allows for 6 channel attenuation...
Behringer Ultralink Pro MX882
I can't comment on the audio quality, or if it has muted outputs for power on/off.
-10dbv to +4dbu
I think you are asking for a -10dbv (consumer) to +4dbu (pro) converter. Hooking up consumer audio to proaudio generally needs a 12 db boost.
Rane makes a transformer BB22 that is about $140 that does just that.
I have put off purchasing a DCX2496 for that very reason, Behringer says its inputs are servo balanced, I really do not know what that means, but I assume it balances input and output levels when flat (no overall system gain unless wanted). Have you sent a email to behringer about 10dbv level?
I have looked in Behringers user manual (poorly writen) and I see no mention of a -10dbV level.
DBX Driverack PA does have a -10dbV switch built in. Driverack has other problems for me as well.
Do you have problems with your system because of this?
That was what the original post was about yes; this unit will do that as well as attenuate the signal.
Slight over kill for the input I agree unless you are not using all the outputs of the DCX2496 then one or two of these I/O's could be used to up the level into the DCX, and use the rest on the outputs for attenuation.
According to the manual each in/out has a control range from full attenuation to +15dB.
Since I was looking for a pro converter, I checked this unit out, and figured for the relatively cheap US$120.00 RRP you can get a 6 channel attenuator.
I go from my Pre/Pro into the DEQ2496, then via AES/EBU digital into the DCX. They both work fine, I just need a few more dB of boast on the input of the DEQ, and hence a variable unit would be better for me.
Dick,
This shouldn't be difficult job for a local DIY audio enthusiast. Find someone and have them put together a few parts and you should be all set. Probably no more than 40-50 bucks.
Davey.
Davey.
This works well as a six channel attenuator:
http://www.decibelhifi.com.au/prod18.htm
To make it yourself the kit as $33 AUD, but they will build one for you for about $100.
Cheers
Steve
Cheers
Steve
Davey
I am not too bad on basic electronic component construction, I will see if I can find a fairly basic circuit for variable gain that will work with the DCX2496?
Thanks Steve that is what I am using as per your recommendation some time ago, I just thought for some DCX owners the MX882 maybe an alternative that was all.
Dick
- Digital Line Level
- Behringer SRC2496
