I have a Berhinger ADA8000 that the mains transformer has burned out. Anybody knows where I can get a replacement? I read some threads and seems that it's a common problem with these units.
Thanks.
Thanks.
I assume the transformer has several secondaries
If there is enough space in the cabinet, you could use a custom wound toroidal.
A company in Poland, Transformator du?ej mocy, toroidalny, sieciowy, na zamówienie, zamiennik - BADEL Elektronik Sp. z o.o. , makes them very cheap,
not more expensive than off the shelf ones...
