Befuddled with routing
I'm building a multi-effect box and I'm still puzzled about routing. I'm trying to route signals so that each 'module' can be by-passable. Figure A is basically my current set up and the problem is the output of the reverb is feeding back in to itself via the EQ direct output line.
Someone suggested an opamp mixer. But if it's done like figure B, won't there be inverted and non inverted signals mixing together?
Or am I missing it altogether /: ?
TIA
Think "op amp summing amplifier", for mixer.
Here are the classic National Semi application notes with the schematics you need:
http://www.ti.com/lit/an/snoa621c/snoa621c.pdf
http://www.ti.com/lit/an/snla140b/snla140b.pdf
Just remember that the schematics don't show the mandatory decoupling capacitors from power pins to ground. Use 10 uF electrolytic in parallel with 0.1 uF X7R ceramic, from every op amp power pin to ground, with the 0.1 uF connected right at the power pin (not 3 mm away).
Thanks Gootee,
I'm thinking along those lines. My issue with the summing amplifier is, as far as I know, the inverting of the wave and rectifying that down the line.
I found this from Mr. Stevenson's site: Paul In The Lab: Buffered Y Splitter Stripboard Veroboard
I'm running a bipolar supply so I figure nix the voltage divider and add an extra opamp for a 3 way splitter. Here's my second idea.
But I won't pretend... this is my first build and I've been learning as I go... I appreciate the feedback.
I went ahead and wired it up with the second idea and it seems to work pretty well! One issue is the eq switch pops when flipped... but the reverb and dry switches do not pop. Echo is just going to ground for now because that part of the circuit is not built yet.
I'm going to tweak it a bit and see what may come.
