BC560B instead of BC560C?
Hi
If you look at the datasheet for BC560, you will notice that the only thing the B or C designates is current gain (Hfe). The B is the lower gain class. Since in the circuit they are used as a mirror, I don't think it will make a difference. The (rather large:xeye: ) 220 Ohm degeneration resistors will reduce thier gain anyway. If you can match them to a decent degree, or use a "matched" transistor array, you can reduce the degeneration. If the PS voltage is less than +/-15V, the BC559 would work too.🙂
:2c:
