hi all ...
i found marshall tone control circuit for guitar here :
http://users.chariot.net.au/~gmarts/ampbasic.htm
i wanna use it for a bass , wat caps should i use to control bass guitar freqs and make suitable for a bass amp ? ...
i think yes, it's suitable for a bass amp. (marshall)
however You can search a schematics for bass guitar amps...
A lot of schematics is here :http://www.drtube.com/guitamp.htm
See also fender bassman sch. 🙂
passive audio filter (flat) is described on this site : http://www.schmarder.com/radios/tech/tone.htm
Bye 🙂
Bye 🙂
The curve of marshall filter is not very flat, but I believe that you can
be realized with the same caps values.
Obviously these filters must be insert in a proper electronic circuit.
See also http://www.angelfire.com/electronic/funwithtubes/Amp-Tone.html
Bye. 🙂
Bye. 🙂
