Hi all
I'm willing to build a basic looking case to house my chip amp and its power supply.
I first considered putting everything in a wood enclosure because wood is cheap, easy to cut, easy to drill through, good looking and non conductive.
I also considered buying an ABS case but didn't like the look of it.
But then I got concerned by the safety side of things when I was looking for the connections to make to earth my project.
I was planning to ground my pcb, speakers, transformer and its metal casing directly to the earth wire of the mains lead.
All the guides I've read mention a metal case to house amp and transfo (Rod Elliott, Decibel dungeon). So I understand you connect all the ground wires to your case and you then connect the case to your mains earth wire.
My options are:
-It is important to have a full metal case if you want to safely house both amp and transfo
-Is it good enough to have a bottom metal panel and the others as non-conductive material (it's the case of my mini Hi-Fi)
-My first idea of full non-conductive box is isolated enough as long as you ground all the necessary to the earth mains wire
Which one is recommended for a first project (cheap preferably)?
Many thanks
My options are:
Many thanks
Hi all
My options are:
Many thanks
A metal case provides shielding from outside interference (EMI). For safety all you really need to do is be sure the safety ground is connected to the power transformer frame. I don't know which codes apply to where you live. But the current trend by ISO and UL are to require high levels of insulation to make sure AC line voltages do not make it to any surface consumers can come in contact with.
So if your mains transformer has side by side windings safety grounding may not be required.
Using the safety ground as a drain wire for outside interference is not a good idea. It has too much inductance to be useful and may even bring in some noise such as light dimmers and food processors.
If it works fine in a wood box then EMI is not a problem for you. Next step is to line the box with aluminum foil, finally a solid aluminum box unless you are crazy then a silver plated copper box should be quite the thing.
Of course proper fuse size is extremely important.
ES
Many thanks for the reply
I'm not sure I understand that correctly. When you say ground "outside interference" do you mean "the metal case providing the shielding"?
My transformer is rated 72VA so I calculate my fuse size by 72VA/250V=0.29A
I understand it should be slow fuse, is this correct? Also I don't think I will find a 300mA fuse easily so I'm thinking of going higher to 500mA
thanks for the input
The safety ground is just able to route fault currents to a safe place. If you ground the frame of your transformer and then isolate if from the chassis you have met that need. Some folks think that interference such as radio pickup or dimmer noise can be reduced by grounding a metal case through the safety ground. Not only does that not work, but it often makes things worse.
250 & 300 ma are standard fuse values. I would use a 250ma moderate time delay fuse. If the fuse blows at turn on you can size it up. Picking a fuse value that does not blow early but still protects is tricky, because you don't actually have all the information such as what is the maximum inrush current during initial charging.
Is it not unsafe to keep some metal work like the chassis not grounded?
According to Elliott and decibel dungeon the chassis should be star earthed for safety.
The new standard is to have sufficient insulation from any input power source. So if your power cord has insulated conductors inside an insulated jacket and you use an insulated bushing where it enters you have a good start. If your power switch has is a push on-off type with two separate insulators between you and the AC that works. So if you ground the transformer frame of a dual bobbin type and keep it insulated from the rest of the case you should meet all of the current codes. Good insulation is often tested with several thousand volts so a single layer of tape doesn't qualify.
Thanks for your reply Simon
I think I'm gonna go for an aluminium case which I found recently. I've only got 4 aluminium panels on it. Is it enough to protect against EMI?
Also my local store hasn't got medium delay fuse. I could order some on-line but if it's not the right size fuse I'll have to keep ordering and paying the pp.
Can I used a slow fuse instead or is it definitely a medium?
regards
regards
regards
If EMI is a REAL problem you need to totally encase the unit. Four sides should be fine. If troubles turn up you might be able to use aluminum foil to screen things, but it really is only effective at RF frequencies.
Slow blow fuses should be fine.
This description does not address the requirement to have:The new standard is to have sufficient insulation from any input power source. So if your power cord has insulated conductors inside an insulated jacket and you use an insulated bushing where it enters you have a good start. If your power switch has is a push on-off type with two separate insulators between you and the AC that works. So if you ground the transformer frame of a dual bobbin type and keep it insulated from the rest of the case you should meet all of the current codes. Good insulation is often tested with several thousand volts so a single layer of tape doesn't qualify.
"all exposed conductive parts must be connected to the Safety Earth".
nor
"the PE must be permanently and mechanically fixed to the chassis".
nor
"" from?
The UK, like Australia, has nominally 230V AC so it "can hurt" if not earthed correctly. User safety, and not just the builder, is paramount and must override all other considerations.
Frank
Frank
nor
Simon7000 is talking about Class II (double insulated), and you, as usual, are stuck on Class I (earthed chassis).
Class II is more difficult for a DIYer to achieve, especially if there is any external metalwork or the builder is inexperienced. Class I is easy - just earth all external metalwork.
I can never advocate non-professional design, build, manufacture and test of ClassII equipment. And certainly not to DIY Members of this Forum.
The Forum has a rule on allowing discussion of direct on line mains powered projects.
I think a similar rule could be useful and potentially lifesaving for restricting the advice on adopting ClassII in this Forum.
I'll accept
I'll accept
as valid, but not as a criticism nor put down. But as a practical builder aware of the risks involved in using Mains electricity. Anything else is stupid. Ban me if you want !you, as usual, are stuck on Class I (earthed chassis).
paraphrase of most countries' regulations that look after user safety.
I have copies of some of the current and proposed regulations, somewhere. They are not cheap. All of the CONSUMER electronics standards are moving to increased insulation to be consistent world wide.
That is part of the reason you see so many double bobbin transformers. It is much easier to make units using them compliant.
Adding a safety ground wire is best avoided when possible as it really can decrease the quality of the audio paths.
Exactly what Andrew is saying; manufactured consumer equipment is one thing, home made is another.All of the CONSUMER electronics standards are moving to increased insulation to be consistent world wide.
- Design & Build
- Construction Tips
- Basic & Safe Case/Chassis for chip amp
